CO detector
m dewolfe
Member Posts: 92
Who makes the BEST co detector for a commercial application. This would be installed in a large garage with about 2500 sf and four unit heaters. A recent vent failure caused a very high reading {400 ppm] and the customer wants a safe,effective solution.
Just a note,
If you have cars or gas powered vehicles in the building, The CO det. will go crazy with alarms. Dwyer is a large testing and alarm co. Spill switches, perssure controls and other saafety controls can also give you protection. Also, regular service probably would have detected this problem.0 -
Check the Macurco web site believe they have CO detectors that operate garage ventilaters.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 95 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
