Excel sheet on gas meter revolution for BTU?
Vlad
Vlad Member Posts: 16
This file was converted from Corel Quattro Pro to Excel, conversion should work. There is a link to the weather office to get proper athm. pressure, but it's for Canada, you can change it to the location you're in. The boxed cells are the only values you need to supply to get the rate. Hope it works for you.
