radiant options
clammy
Member Posts: 3,213
Looking at doing some radiant in my home with some radiant panels also .Now heres my question and i know i am at the right place i'm looking for using a low temp so i know oxion tubing is out of here and this is a staple up am i better with pex and plates or pex staple up mostly all tile floors and would be step up on constant circ outdoor reset with panel rads and txv since i already know i can't meet the lose with rfh alone thanks for input .I'm also going to use a munchkin t80 vision one at a minuim but may spring for the i believe vision 3 which uses 3 way valves and modulates boiler to lowest temp load calling thanks and peace and good luck
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
