using regular vent in place of main vent?
Joe_39
Member Posts: 47
rather then when boilers been running a while (and rads giving off heat)???
can you get away with using a regular radiator
steam vent instead of the bigger main vents on a small steam system??
According to the gorton brochure, a type D vent is equal to 27 regular vents..
For ease of install (and lack of overhead space) could you use one of these in a small house/small boiler setup..
Like a steam main thats 25 feet or less?0 -
The D vent
would work well. I've done this if space was limited.
Should work fine...
But here's the test.
See how long it takes steam to get from the boiler header to that vent with the vent removed and the pipe wide open. Then time the same thing with the vent in place. If it takes much longer, you can do a better job with a bigger (or with more than one) vent.
Ed0 -
yep.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 970 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
