Programmable Thermostat
Joseph
Member Posts: 1
I'm looking for a t-stat that would operate by a space sensor and an outside sensor.
I have a 2 stage Heating and Cooling machine for 100% Outside Air. I want to keep the space at 65 troughout the year. I need a Thermostat that will read the Outside temperature and the Inside Temperature then decide if we need 2 stage cooling or one stage or no mechanical cooling at all. The same with Heat.
Any suggestions? I thought of the Honeywell T7350.
Standard digital stat should do
With the addition of Honeywells damper actuator, enthalpy controlls and either a mixed air sensor or supply air sensor or both. It depends on how much control you desire...Lo ambiant lock outs etc...What is the application?0
- 125 Chimneys & Flues
