storage tank
looking for a diagram on how to pipe an electric water heater to a tankless coil as a storage tank using the thermostat in the heater to control a circulator
  • william_5
    william_5 Member Posts: 62
    > circulator
    ok bert i use al smith ele water heaters first make shore the supply tube does not have a check vale in it this will be the main water supply to the heater all 3/4 " top of the tank brass tee top of the tee main water supply on the bull 6" brass nipple& elbow &sh nipple taco 006 bt4 pumping up to tank less coil [ this will pull the water from in side of tank] pipe this to your coil the other side of coil gets piped to the bottom of the tank remove drain vale all brass 3" nipple 3/4" ball vale sh nipple, tee drain vale on the tee will be the supply from the tankless coil all the pipes i run to the top of the celing
    ele now the heater has 2 elments the top one i wire out so its not used the bottom thermastat i use power goes in to handy box with switch power goes to thermasat back up to taco 006 than to nutel this is done all with 110vs
    [not 220] hope this helps
    william
  • william_5
    and the tot water goes to the fouct
