Radiator Vent valve placement for Steam
brucewo1b
brucewo1b Member Posts: 638
the end of the radiator and you might see a flat round spot to drill and tap in a vent. Check out this article by Dan.
http://www.heatinghelp.com/newsletter.cfm?Id=20
  • Jason laurelton
    Jason laurelton Member Posts: 13
    Radiator Vent Valve Placement
    Hi Guys,
    Today I took a radiator from my house that has hot water heat and installed it at my parents house using steam heat. The problem was the valve. For hot-water the valve is in the top right hand corner. For steam heat can I place the valve in the top right hand corner or do I need to place the valve in the middle (which is not possible) ?
