Copper and Near Boiler Piping
Paul Pollets
Member Posts: 3,669
Dialectric unions are not required on closed loop systems. The unions have a high failure rate on the gaskets and will cause a future problem...sooner, rather than later.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=104&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Is it ever ok??
Is there any circumstance that copper is ok in near boiler piping? It was mentioned to me it depended on the thickness of the copper.
Thoughts for the pros?0 -
for a steam boiler??
never..
Copper?
Is it being done??...Yup
Is it right ??...Nope
I use coper below the water line on returns to keep them clear and from rottng..
But i would never use it above on supply piping
David0 -
Even on a water boiler...
unless it is a non-ferrous system, we use black iron for the near boiler piping, and then either pex or copper from there on.
Add me to the list...
Never.0 -
Love this site
Talked to someone today who told me if it was "K-Copper" then it was ok to do the near boiler piping with it.
Guess I move on to the next guy.
Thanks guys.0 -
the first time you put your little finger through ....
a piece of copper foil pipe you immediately Know the answer to that question. that is why ,...you,... the homeowner, can help yourself by reading some of Dans books,visiting his Library or asking here at the Wall...or by helping someone else who has not had the advantage *~/:)
we thank you too ...
somehow i thought you were speaking of steam boilers...
solly bout that.0 -
Sanity check
As a newbie, I just "needed" that sanity check on something that ran counter to everything I have read. That is why there are newbies in the world...0 -
Patrick,
Black pipe/fittings allow movement in the threaded/screwed connections when the piping expands and contracts. Soldered copper fittings don't, so they twist and ultimately leak. The thickness of the copper really doesn't matter.0 -
What????
On steam I totally agree, however...
To say that copper is not to be recommended on a hot water boiler's near boiler piping is without basis. You do need to transition from the cast iron through a dielectric union or dielectric material(brass is allowed by plumbing and mechanical code), but from then on there is no reason to not use copper.
The difference between different grades of copper pipe are solely based upon wall thickness, starting with DWV yellow stripe, then M red strip, then L blue stripe, then K green stripe. K copper will have a longer service life compared to L or M (DWV can only be used on plumbing drain waste and vent)but with a heating system properly designed and using correct flow rates for the size of tubing being used it will outlast most boilers (50 year warranty ring a bell?).
I know this question was probably in reference to steam, but the way everyone jumped on the bandwagon, I figured someone better stick up for copper. If someone disagree's give me a good reason for it.0 -
near boiler piping
I have been working for a established in floor heating company in the Northwest United States. We have been using copper (type m or l, depending on the contracts) for years on glycol or water systems on the boiler loop as well as the injection and system loop. We have done commercial and residential snowmelt and in floor radiant systems. In fact, I prefer the copper right off the boiler compared to the black iron look. We do not use dialetric unions because they fail and it is on a closed system. Although we may have had more problems with solder joints in glycol systems, we elect to use them.
I have NEVER heard of only using black iron on boiler systems, and eventhough I dont oppose to use black iron, I think copper is faster. Depending on the type of copper, you will loose some gpm on any loop (boiler, injection, or system), but otherwise, I prefer copper. In the past, my boss has upsized the piping to accomidate any size of copper.
Cheers,
PexRunner
I'm sure all the posters would agree with you about copper, and the assumption is that the question was asked about steam piping.
It's a question that's asked here often, always about steam.0 -
Why would you....
Why would you need a dielectric union on a closed system? Oxygen needs to be present in order for there to be a problem, no??????
Yes, for a Steam Boiler
Steam is correct...sorry for not specifying - I have blinders on I have been so consumed lately....0 -
Electrolysis
> _A
> 410&Step=30"_To Learn More About This
> "Find A Professional"_/A_
Dielectric's
Yes they are.
***IMC section 1203.1.1 Joints between different piping materials. Joints between different piping materials shall be made with approved adapter fittings. Joints between different metallic piping materials shall be made with approved dielectric fittings or brass converter fittings.***
Any time you have two dissimilar metals such as steel (cast iron or regular) and copper, they must be isolated to prevent electrolysis. Water is the transfer medium whether there is air present or not. If you don't like the gaskets on standard dielectric unions, brass unions or nipples are an acceptable replacement, or dielectric nipples (though I disagree with some regarding how they are truly a dielectric).0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
