Thread sealant 565
ALH_4
Member Posts: 1,790
I dont think <a href="http://tds.loctite.com/tds5/docs/565-EN.pdf"target="_blank">565</a> or <a href="http://tds.loctite.com/tds5/docs/592-EN.pdf"target="_blank">592</a> will do it, but I have used <a href="http://tds.loctite.com/tds5/docs/545-EN.pdf"target="_blank">545</a> which worked great.
-Andrew
-Andrew
Sealing threads
Has anyone ever used this sealant to put together 1/2 ips to 1/2 straight fitting? Do you need tephlon?
I found this.
Massachusetts
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
