Adding heat to garage
BILL GARNETT
Member Posts: 12
YOU COULD ADD A HYDRONIC UNIT HTR AND A STRAP ON AQUASTAT TO CONTOL THE FAN SO IT ALLOWS THE FAN TO TURN ON WHEN IT SEES 140 DEGREE WATER
Adding Heat to garage
I have a Oil hot water system and would like to add heat to my garage. What would be the best way to accomplish this? I am in the process of replacing my boiler etc and was wondering what would be best for heating the garage. The garage is about 20 x 20 and I currently have 3 zones in the house. The boiler will be in the basement which piping can easily be run to the garage.0 -
If there is any chance
of freezing you have to leave it on a low level thermostat to keep the area heated or add anti freeze.
In place of applying the anti freeze to the entire system you can isolate it with a plate to plate heat exchanger but you have to fit it out like a small boiler.
Mitch S.
Bob...............
Bill has a good idea, and Mitch is right too! If the door was left-up, would it freeze? You may want to look at a heat-exchanger for just the garage, or circulate glycol(anti-freeze), in the whole system.0 -
Garage
I added a modine unit in my garage last year. It is pretty small but it heats the space right up.
We put in a t87 with lower temp capability - i think it goes down to 40. If we leave the door open, we waste a lot of energy, but nothing is going to freeze........
Did not use an aquastat since its 5 feet from the boiler and I didn't care if we blew cold air in the bsmt.
I highly reccomend the system. We were going to put in some really large CI radiators, but the modine really blows the heat around and is small.
I will post a picture if anyone wants to see it.0 -
yes please post a picture0 -
I got me a
ductless mini split heat pump. My garage is detached. Keeps me chillin' in da summertime, toasty when there's frost on the punkin'0
- 86.9K THE MAIN WALL
- 57 Biomass
- 110 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 981 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
