steam pressure
something tells me that's a hot-water system, not steam.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • M Tess
    M Tess Member Posts: 2
    steam pressure
    If the pressure gets up to 11 psi and temp at 190. can this cause some pipe nipple failures? How about pipes against the wood getting to hot.
  • Al Letellier_9
    Al Letellier_9 Member Posts: 929
    pressure
    Something is wrong with your figures. You can't get steam, let only 11 PSI with 190* You need to make at least 212 degrees to boil the water and more temp to reach 11 PSI. Get a pro in there to figure this out.
  • M Tess
    steam
    Thanks al I was reading the guage on the top of the boiler. Thats where I got those numbers. It's a brand new guage. I was just reading some of the steam book. Maybe the guage they put in just isn't sensing properly. The system works fine I was just wondering about the numbers.
    Thay seemed off.
