water in air vents
T_2
Member Posts: 19
What does it mean if I have water in the Air vent? The Rad was clod so I unscrewed the vent. When I took it out, water came out of the vent and a little from the Rad. The RAd then started to get hot right away with the vent off. The Rad does have a backpitch of about 1/2" it is 4 ft long.
What is wrong with running the heat with air vent off the rad? It seems like a solution.
You need
a new air vent.
Running the heat without the vent will allow steam out of the radiator. Not good.
Mark H
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 69 Pipe Deterioration
- 956 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
