you have got to look at this
Interesting.
Ken Secor should be especially intrigued.
  • Leo G_99
    Leo G_99 Member Posts: 223
    check this out!
    http://www.weidmann-industrial.com/paramax.html
    The future is NOW!
    Leo G
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    I bet they...
    will work great until the dust kills the reflective part...
  • Ken_40
    Ken_40 Member Posts: 1,310
    Mike,
    Being the skeptic I am, I have serious doubts about the product claims, as I suspect anyone who was not sleeping during 8th grade science may too.
    The website suggests radiant energy losses are far greater than convective or conductive. This fundamental flaw in their "reasoning" makes us want to hit the delete key before long.
    The bubble foil guys tried and lost, I think Mark Eatherton actually messed around with that stuff and found it "less than adequate for the intended claims and purpose."
    Is any reflective surface of any shape better than none under a staple up install? I suppose so, but not in light of other cheaper and easier apps. IMO.
    My staple up radiant on my just completed own home, was with aluminum plates, and 2" aluminum-faced rigid foam, secured to the "flange" of the OSB manufactured floor joists. This allowed ~2" of air space between the reflective face and the sub-flooring. The remaining joist-bay was then stuffed with 12" f.g. insulation, then sheet rocked.
    Given that our design temp here is 30-below, I am sure the method is sound and the designs make for great comfort with very low water temps.
    The major drawback (besides the obvious marketing BS) with the product mentioned would be the curvature of the "parabola" would reduce the dimension remaining for insulation by a substantial margin.
    Adding to what my wife says, "You can never be too rich, too thin, or have enough insulation." (;-o)
  • Cosmo_3
    Cosmo_3 Member Posts: 845
    Here is a positive
    The only good thing I can say is that it can help create a sealed air pocket for the open 2X4 truss systems, however the foil has nothing to do with that. The same could be done with scrap cardboard.
    Ok, that is the only positve thing I can honestly say.
    Cosmo
