heat exchangers
doug lewis
Member Posts: 1
I recently bought a Bosch hot water exchanger which i haven't installed because i was told that someone (buderus, bosch, etc) had a unit that would both heat my water and replace my boiler to heat my home with my hydronic system. This 2 tank system should do the job for me as i would be able to eliminate both the hot water heater and my antiquated boiler which heats the hydronic system. Is there such an animal out there? If so, i know a lot of folks who would be in the market for such a unit!!
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
