What is it???
It is a front sight for a bow and arrow.
  • Timco
    Timco Member Posts: 3,040
    House built in 1986, HO said this has always been on the 90% furnace I serviced today, and said I could have it. If you tighten the rear thumbscrew, the light comes on. Seems to have a set on the post where a wire can be attached.
    Tim
  • Timco
    I've seen many sights, but how would the light help? not a laser, just a light. I do not use a sight personally.
    Tim
  • Maine Ken
    Maine Ken Member Posts: 531
    Illuminates the fiberoptics. Makes the pins glow so you can see them in low light.
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Unless you're playing some sort of game that's surely a pressure-actuated device intended for use during setup/adjustment/inspection. Likely VERY important and should never have been removed.
  • Timco
    No game, was just sitting there on top of a 90% unit. Just how would this work and where would it go? Is it left installed? The thumbscrew lights the light, but otherwise it is just a threaded post with a thumbscrew on the post where a wire can be attached. Ideas?
    Tim
    From appearance almost certainly has to do with pressure.
    Is the "post" not hollow?
    If so than suck or blow on it while playing with the thumbscrew and the operation of the light will surely change.
    If not hollow, my only other guess is that it's related to temperature. Use a match or a lighter on the post while paying with the thumbscrew to affect the light.
    If you're wondering about the power source, my guess is that you unscrew just below the lens to reveal the battery.
  • Timco
    Batteries are behind the light. Post is solid. Heat does not light the light, or turn it off. Thumb screw behind light turns it on, and the flat washers after the lock washer and on top of the thumbscrew on the post would indicate a wire could be wrapped around the post, but why? Why such a long post? WHAT IS IT??? I will not sleep until I know!!!
    Tim
  • Timco
    More shots....
    T
  • EJW
    EJW Member Posts: 321
    Sight light
    The other guys are not messing with you it is for lighting your bow sight pins. Here is a similiar set up.
  • EJW
    Timco
    wanted to know if you had seen my answer? :)
    EJW
  • Timco
    Like this??
    Tim
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    I could have
    used that Sunday morning!!!
    Don't ask......it's too depressing.
    Mark H
  • jackchips_2
    jackchips_2 Member Posts: 1,337
    Maybe
    we like being depressed--tell, tell.
    Jack
  • Brad White_9
    Well
    all I'll say is..................
    LOTS of points, 20 yards, couldn't see the pin.
    If I say anymore, I'll start drinking. Again.
    Mark H
