Pressure cut off
fsk
Member Posts: 31
What shall be the ideal pressure cutoff and cut in for a residential boiler?
Any and all answers are appreciated.
Thank you.
Thank you.
pressure settings
As low as you can get it to feed the furthest radiator. With standard pressuretrol, the lowest settings are about 1/2#-1 1/2 lb. You can use a vapor stat and get it even lower.
- 114 Geothermal
