Heating and hot water system replacement
laura evans
Member Posts: 1
We are looking to replace our 212,000 BTU boiler for a 3000 SF split level. We are looking to replace it and separate out the hot water heater. Does a solar hot water heater work in upstate new york? Any ideas of which one. Can it be combined with a new Weill McLean boiler and a Beckett Burner?
Hi Laura
The answer to your question(s) is.....that depends.
Solar does work in Upstate NY, but it does have limitations. Yes, it can be supplemented by another heat source when the sun just doesn't shine.
Where in NY are you located?
Mark H
solar data
if you go here, theres a solar output map of the US, second down on right of page you can click and find solar data near you.
http://www.thermotechs.com/energy.htm
this can be a starting point of the amount you could assume to get.
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
