Barametric
massrookie
massrookie Member Posts: 22
As an oil burner tech I would love to see more dual dampers in use....excess draft lowers efficicency(more heat up the chimney) and effects flame quality, sometimes to the point of causing burner shutdown. Something to remember if you have a tall chimney and/or live on a hill or in an area with high winds, just because you have the proper amount of draft while having the annual service in dead air in August certainly doesn't mean it will be O.K. during the winter months....
Pat
