Lux Thermostats
brucewo1b
Member Posts: 638
can not be used on Conventional 24V Heating and Cooling Systems, Hydronic (Hot Water) Systems
Lux Thermostats Question
Can a line voltage Lux ElV1 programable thermostat be used on low voltage controls. When doing a oil fired boiler upgrade that already has line voltage controls, can the ELV1 thermostat be used on a 24 volt circuit for zone valves. Or must it be only used on line voltage circuits.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
- 49 Job Opportunities
