Boiler service
tom_11
tom_11 Member Posts: 58
Thanks for the info but the mounting plate is leaking and the refractory need to be replaced,the new kit has what looks like putty. But it is hard so what is best to use. Thanks Tom
  • brucewo1b
    brucewo1b Member Posts: 638
    As Norm said you can clean through the burner mounting hole, however many of this units by now have flue gas seepage by the chamber mounting plate and I now use 3/8 stove rope around the plate glued on with RTV Silicone and it makes a better seal than the gastket material that is sent with the chamber kits. I was told by Al from Portland I think that a bit of anti-seeze on the boiler before putting back together will keep the gasket from sticking in the future.
