Push or Pull
Spitfire
Member Posts: 2
I will install a B & G booster pump for a new toekick heater in a remodeled bath. The toekick is replacing an old cast iron hot water unit. Because of space limitations under the floor can I install the booster pump on the return line instead of on the supply line?
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
