Warren Webster unit heater
Glenn Leber
Member Posts: 1
I am trying to find the BTU output of a Warren Webster unit heater, the model number is 18H22, order number 58 UH 2040. I believe it would be in the 100K range has a 1/6 HP 3 speed motor, 18" fan, double row coil. I noticed old American unit heaters used a similar looking model number although none the same as this one.
unit heater
I'd be suprised if a unit heater with a coil that size was more that 75,000 btu steam.
The only Warren Webster UH I have seen was pretty much a direct knock of of a Modine heater. (rebadged maybe?)
Try looking at a similarly sized Modine unit, should put you in the ball park.
Good luck,
JimThere was an error rendering this rich post.
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
