Condensate line type
Brad White_9
Brad White_9 Member Posts: 2,440
and if buried, Sch. 80 for longevity. Yes, I would neutralize the stuff regardless. No telling what it will see for material downstream. Search for the recent/ongoing thread on neutralization.
Gravity is fine if you have height. It works.
Newton's Fourth Law: Gravity Wins.
  • Xc8p2dC_2
    Xc8p2dC_2 Member Posts: 150
    What ya using?
    Heat Co wants to pump up and drill a hole thru top of foundation to outside
    My choice would be to run about 15 feet from ModCon to drywell, below grade cellar floor... What type of piping needed? [PVC? PEX? or ??] and should it be neutralized?given it would be a dedicated hole, non sump... I assume you don't use a pump if conds line is gravity positioned?
    The experts on this site seem to be lightyears ahead of most of industry professionals in my area, This site is such a valuable asset to the industry... Kudo's to all who contibute.. Thanks
  • Xc8p2dC_2
    I can pre run the condy line for them and add a M-chip filter in the dry well, but they say they don't usually neutralize, when pumping out
    and since I have a wifey and flowers, I guess it's best to avoid all types of confrontations
