wireless sensor
Brian
Member Posts: 285
I have a customer that had a wood stove installed with a water jacket that was piped under slab to a water heater to supplement his domestic water.The idea apparently was for it to work by gravity.Well it works by gravity but both ways,so now when the stove is not in use the water from the heater goes into the slab causing the water heater to run a lot more than it should.There is no easy way to run a sensor line from the water jacket to the water heater so I thought that a wireless sensor to a pump at the water heater would be the answer.
Any Thoughts.
Dobber
Any Thoughts.
Dobber
Clamp on aquastat and relocate pump to stove
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
