Need a manufacturer for a 1 1/2\" three way zone valve
Ray Landry
Member Posts: 203
Hey guys wondering who you use for a three way 24 volt 1 1/2 zone valve? I've tried honeywell and taco and neither make one. I've heard Barber Coleman are good but from my local supplier they are two weeks out. Next I'm thinking of trying Belimo? Probably pricey though..
What kind of flow?
Caleffi has 1-1/4" with a Cv of 8
hot rod
Hot Rod's right. Check the flow requirement because pipe size may not be the determining factor. With an 1 1/4 8CV valve, there is quite a bit of flow and BTU capacity. Let me know if this does not work for you and I'll find you something bigger if that's what you actually need. Let me know what your flow requirements are.
Roger M.0 -
honeywell absolutely makes one, but it may not be available from your local plumbing supply.0 -
Thanks for the help guys. According to my honeywell rep (honeywell tech support does not offer commercial support apperntly) HOneywell only makes three way globe type mixing valves not three way bypass zone valves. I need to move 17 gpm through the coil.0 -
1 1/2 three way valve
try Invensys erie valve division.they have a great variety of valve configurations and operators0 -
honeywell revisited
Honeywell does make 3-way ball valves with a variety of direct mount actuators in 1/2" thru 2". type VB3----
Fairly inexpensive. If your local distributor does not have, the biggies like Minvalco, Neuco, etc. often can ship to them same day typically.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
