Drilling into old cast iron rad
Brad White_9
Brad White_9 Member Posts: 2,440
Sharp and cool. Go in straight using a guide if you can. Carbide bits or high speed steel; depending on graphite content, you may get only one or two uses out of HSS (and no one really re-sharpens drill bits these days, do they? )
Also when tapping, go in one direction only. Do not back-out to clear chips until you are done. If you do back out mid-tap, you run the risk of chipping the just-cut lead threads. Use plenty of oil here too.
