pri / sec question
Timco
Member Posts: 3,040
Does the pri loop need any flow control? 30' or so of 11/4 pipe with a 007 moving it. 162,000 BTU atmos CI boiler.
Thanks,
Tim
Thanks,
Tim
Second....how many BTU's typical for a 60 gal indirect?
Thanks,
TimJust a guy running some pipes.0 -
I install one...
use B&G Checktrol flanges for the pump, so they are built right in.
As for the indirect, you can find charts that will give recovery rates for different flows and boiler BTU's, like this for the WM tanks.
http://www.weil-mclain.com/netdocs/ratingsplus.htm#RATINGS
Floyd0 -
Is there a GPM we are looking for?
TJust a guy running some pipes.0 -
That's up to you...
within reason and pipe sizing.... as that graph shows... more flow, more hot water, more btu's more flow needed. One thing to watch is that some indirects run very high heads and you need to take that into account when sizing the pump and piping.
Floyd0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
