Boiler vibrates and smokes at start up
JK_4
JK_4 Member Posts: 35
Yes it does sound like oil equiptment and should be checked by the installer. Depending on your tank location and where the oil lines run it could be a leak or some other way that air is entering the oil line.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=417&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • P Williams_2
    P Williams_2 Member Posts: 1
    I had a new oil boiler installed,a few months ago.I went to put it on but it vibrates and smokes at start up.Thanks for anyones help.
  • Empire_2
    Empire_2 Member Posts: 2,340
    PW......
    Call the installing contractor RIGHT NOW. There should be no problem with them coming out to remedy the problem. It may be just something over looked or that the system was not set up correctly from the get go....... Call and they probably should be glad to help.
    Mike T.
