Unwinterized system?
Steamhead (in transit)
Member Posts: 6,688
but I suspect the system froze. Your best bet would be to call a pro to look at it. Sometimes it only cracks in a couple places, other times the system is a total loss.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Possibly unwinterized system
I am just looking for a quick estimate and your thoughts.
We are looking at a foreclosure in extreme southern IL, built 1910, 5500 square feet, Weil-McLain boiler. Second story ducted and something in attic for air conditioning.
Problem is realtor thinks the house was not winterized properly in 2004 winter and radiator (?) leaked. She just got the listing. 2 oak floorboards (app. 18" long) in foyer are buckled under the radiator. Rest of house is carpeted. No evidence that others leaked. Does this make sense? If water was not drained out of boiler, would all the water leak out of just one radiator and would it just buckle two 2" oak boards or would it have damaged a larger area of the floor there? If they didn't drain the boiler, does this automatically mean the boiler is damaged? Shouldn't other water pipes have frozen, also? Even when it is below zero here in Montana, our house never goes below freezing inside. I am wondering if the damage occurred longer ago and if the system is okay. Appreciate your thoughts!
When my husband looked at the house, the realtor had two hvac guys there who recommended putting two $ 6,000 95% efficiency furnaces in the basement for the first floor and one furnace in the attic to use the air conditioning ducting there.
So, for the quick estimate. Approximately how much could we expect to spend to replace the boiler?
We have a bunch of very old houses but none with steam or hot water heat.
Thanks to all of you! We really appreciate and benefit from your advice to others here on this forum.
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
