heating
Carla
Carla Member Posts: 1
I have a 10 year old peerless cast iron steam boiler. It is giving hot water but the steam is not risng to heat the house. Please help anyone.
  • fred m.
    fred m. Member Posts: 1
    heating problems
    my heating system is a york diamond 80, it has a automatic pilot ignition system, the fan runs but the burners don't light. what seems to be the problem. thanks.
  • brucewo1b
    brucewo1b Member Posts: 638
  • tim smith
    tim smith Member Posts: 2,886
    Furnace problem
    Was your air filter plugged with dirt, or maybe return air grills covered in house or supply registers closed. Sounds like possibly the furnace limit is open causing fan to run but burners won't. Also could be ignition failure, some furnaces turn fan on with fan timer only and no heat sensitive fan switch. 1st make sure filter clean and then try turning power off for one minute to furnace and then back on and see if it fires. Good luck, Tim.
  • S Ebels
    S Ebels Member Posts: 2,322
    Carla
    Post this as a new message and you'll get a response. No one is seeing this because it's attached to this other guys thread.
