Turbomax indirect water heater
bob_84
Member Posts: 10
Anyone have any experience / feedback using the Turbomax indirect tank mfg. by thermo 2000.com in a residential multi-family application?
turbomax
We have used over 30 units with great success but make sure it is installed correctly proper circ size and piping are crutial0 -
I understand that to much flow is as bad as not enough. This will be connected to a GB 142 / 60 using the pre made manifold outlets of 1" then increased to 1 1/4 for the 23 or 34 depending on the one we select. Do you think as good as Buderus ST 300 tank ?0
- 119 Geothermal
- 394 Solar
