Viega Press system
Ted_9
Ted_9 Member Posts: 1,718
All this talk about what is a leak in the Propress threads has got me thinking.
Has anyone seen "leaks" in the pex press system? I'm including pexcel and fostapex.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=373&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • S Ebels
    S Ebels Member Posts: 2,322
    Love the stuff
    We've installed literally miles and miles of both types. Not one single, solitary, lonely leak. My personal opinion is that their joining system is one of the best if not the best for pex piping due to the fact that the sleeve contacts much more tube. Just compare the length of the stainless sleeve to the standard 1/4" copper ring you see on most run of the mill pex jobs. Their fittings are different than most also due to the greater number of "ridges" or contact points. Many fittings I see have only 3 or 4 while the Viega fittings have 6-7. These contact points are what actually does the sealing on a press fit and their wide sleeve takes full advantage of that.
  • bovide_4
    bovide_4 Member Posts: 161
    for this reason
    I am most comfortable with Uponor propex fttings for the way they are joined.
