Cast Iron vs. Steel?
ALH_4
Member Posts: 1,790
I'm not familiar with the EK boiler, but I am familiar with the Viessmann boilers. The Vitola Biferral is unlike any other boiler. If I was burning oil in my own home, I would use a Biferral. You could connect it to a 4-way mixing valve or use a Divicon mixing station. Set it on a Horicell indirect water heater and you still have a pretty compact footprint.
-Andrew
-Andrew
Cast Iron vs. Steel
Hi,
Looking to replace a 30 year old New Yorker (Oil Boiler). Not sure if I should get a Cast Iron (such as Viessmann) or a Steel (such as Energy Kinetics System 2000).
Any thoughts?
Steve0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
