Life expectancy of Glycol?
Saggs
Saggs Member Posts: 174
I have seen many installs that put in "No Burst" or other glycol formula that have leaky valves, gasket deterioration, and "blue crust" around brass valves etc.. I have heard that glycol must have corrosion inhibitors added to it after a certain amount of time to prevent it from becoming corrosive. Any thoughts on this subject?
  • hr
    hr Member Posts: 6,106
    test it yearly
    is the only way to know if the inhibitors are still good. If you have no leaks, all barrier tube, and no fill fluid being added, AND it is not overheated due to poor flow etc it should last 15, 20 years or more.
    Of course a cleaned system to start with makes a huge difference in the life expectancy.
    Most glycol manufactures will provide an in depth anaylsis of the fluid for you and supply needed inhibitor boost package.
    hot rod
  • Drew_2
    Drew_2 Member Posts: 158
    Life or death
    Hot Rod hit it on the head.
    If you'd like to do some reading, go to noblecompany.com, highlight tech, highlight fluids and click. There are about 30 documents on antifreeze , water and others.
    Or call me at 800-678-6625, Ext 108
    Drew
  • Saggs
    Thanks, drew and hot rod for the info, I will call you with some questions drew.
