Air Vents
Guest_5
Member Posts: 35
Hi all.
I am curious if the position of an air vent play a part in heating at all? I have one radiator which when I tried to tighten the air vent, the hole faces the ground (upside down). In this case would it affect the heating procedure? And if so, should I use angled vents on such radiator?
Also, I have an old air vent on the main which is stuck or rather, painted over along with the main pipe.
Thank you in advance.
The hole in the vent
must face the ceiling to work.Retired and loving it.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
