Balancing Mouat Heating System
Rodney Summers
Member Posts: 748
I have an old Mouat system which all but one of the original valves have been replaced. All of the wet seals are in place. I am in the process of regulating the valves so not to get steam into the dry return. I installed a vaporstat and set the pressure at 3oz with a subtractive difference of 3oz. I set the thermostat at 72F and the room temperature was 68F. The boiler is currently cycling about 65-75 seconds. Can I adjust the valve such that the wet seal trap can reach a certain temperature? What would be a good temperature? I am measure between 80F- 160F currently at different radiators.
Hi Brian, I also have a Mouat heating system.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
