pulling hydro heat from bottom of steam boiler
john_132
Member Posts: 1
i have steam heat in the main part of my house. we pulled two zones off the bottom of the boiler for base boards in two seperate parts of the house. one zone, on the second story always becomes air bound. when it does gravity takes effect and water floods the boiler. there is a check valve on the feed side before the circulating pump. i was told i need one on the return side, however i do not understand how or where to install it. any help
check out....
http://www.heatinghelp.com/heating_howcome6.cfm ....it should help...kpc
baseboard and steam heat
I have found the best way to add baseboard heat off a steam boiler is thru a heat exchanger then there is no chance of flooding the boiler0 -
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
