Repairing pipe on steam system
Chip_5
Member Posts: 5
My friend is away on business and last night his wife called about water in the basement. The source was the elbow on the hartford loop on his steam system. I was able to get the two pipes that lead to the elbow off and now have to replace a 21 3/4 piece, a 5 1/2 piece and the elbow for 1 1/2 inch iron pipe. How do I piece this together. When you screw the pipe into the bottom fitting it is going to unscrew at the top. Is there a coupling that makes this possible? Thanks!
YEP
it's called a union. Some supply houses will cut pipe to sketch. Make a drawing and bring it to 'em. Do ya have the right tools? Maybe a pro should be called. "Little" things like this can be a PIA if ya never did it before.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
