boiler temperature control
john webster
Member Posts: 1
my boiler appears to be working quite normally and is switching on and off by boiler temperature as normal. however, even with the boiler setting temp at minimum the radiators are much too hot. Is the problem associated with the c.h. thermistor or the p.c.b.
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
