Noise in boiler
S Davis
Member Posts: 491
Sorry double post.
Noise in boiler
I have a gas fired hot water boiler with 3 zones. Water temp is set to 180. I have blead the system of air and replaced the expasion tank because of a leak.When the system is under fire and coming up to temp I hear what sounds like expansion noises at the boiler and every so often I get a single thump.I have all baseboard radiators and the sound is not the usual crackling noise that you hear when a zone calls for heat.I run about 20 psi under load at the boiler. Any ideas on this problem? LT0 -
Noise
Does it sound like a tea kettel comming to a boil?
S Davis0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
