valiant boiler help needed
jenny
Member Posts: 1
we've just moved into a new house and it has a valiant central heating boiler but no seperate thermostat. the old owners have left us nothing to say how we set the central heating to only come on at set times - can anyone help?
Jenny
We need alitle more info.
What does your house have for heat in the rooms ? Are they panel radiators that hang on the wall ?
I am thinking you might have constant circulation and each room has a thermostatic radiator valve to set the temperature for each panel.
Have you found Any Control on a wall ?
How is your domestic hot water made ?
Pictures are a Great Help.
Scott
You may have a timer on the boiler for contoling the central heating. If its a combi as long as the appliance is turned on you will get hot water.
More info like the previous suggests will help us help you.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
