Ifc board
Timco
Member Posts: 3,040
Blower comes on when unit is powered up and a demad for heat is present. Usually for only a minute. Fan control bad?
Tim
Tim
Goodman IFC board...
... When the disconnect is switched on, blower runs constantly, no heat, nothing,,... blower keeps running...
Transformer is good, 120 in primary, 24 in secondary, fuse on board is good... no apparent damage of any sort... BUT, when I try to jump the terminals, I get nothing.. R to W, R to G... NOTHING....
What else could it be if not the board?
no fan control board.. just a simple IFC... its a 90 plus... i figured if i jumped the terminals, that should suffice... BUT, the led doesnt even come on, so there's no LED codes to read...0 -
If the lv cicuit was open, the led would tell you. No led usually says bad board. Check continuity of safty loop?Just a guy running some pipes.0 -
Usually
If the main fan comes on at power up it's an indication of a popped limit somewhere in the string. Check your roll outs and the high limit. This will happen even if there is no call for heat on a lot of makes depending on the "logic" built into the board. Some makes will run the inducer along with the main also. The board would be the last suspect but it's surely possible.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
