Steam radiator hook-up question
Steamhead (in transit)
Member Posts: 6,688
go onto a correspondingly-sized radiator valve. It's not a standard pipe union. It will take some work, but you need to remove the tailpiece that goes into the radiator. Then screw a bushing in to reduce the size to 1 inch, screw in the tailpiece to your 1-inch valve and pipe it in.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I need to connect up a small steam radiator (25EDR). The question I have is that I plan to hook it up using 1 inch IPS, but the current union on the radiator is either 1 1/4 or 1 1/2. Can I use a bushing to downsize from 1 1/2 | 1 1/4 to 1 inch (at the radiator union) or is there some better way to accomplish this?0 -
Another way to accomplish this which I prefer if possible is to use a reducer coupling on the riser to the valve(less problems then trying to get some of those spuds out and less condensate siting in yhe radiator)
I probably should have done the reducer option. Taking out the existing union has proven to be a nightmare. Now I'm stuck where the piece of the old union is stuck threaded inside the radiator (it has probably been there for 100yrs).
I am having no success getting it out and I've even hosed myself so there's nothing to grab on to with a pipe wrench anymore. Any tricks of the trade?
Sigh....0 -
Pete
I usually cut the nipple carefully to the threads in the radiator but try to no nick those threads in three places, then take a chisel and colaspe the nipple and then you can pull it out or kind of tread it out depending on how it colapses.0 -
That's how I do it
make a couple of cuts about 1/2-inch apart, not quite down to the threads. I do it with a Sawzall, but you'd probably want to use a hacksaw blade to avoid nicking the threads.
Thanks for the advice from both of you. I think we've salvaged the radiator. Just need to finish up the piping off the main tonight and then we can see if it worked!0 -
Test With Air
If I had the radiator out, I would test with air. Plug all the openings except one and put about 10 PSI in it. its a whole lot easier to clean up an air leak then a condensate leak.
K0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
