what size boiler do i need?
but that doesn`t help, we have to know exactly what your supplying, try Dan`s book, its under the "Shop" catagory.
gas fired steam boiler .
3200 sq ft brownstone in nyc0 -
i forgot
it's four stories ..5 if you include the basement0 -
Well...................
you have to give us some rad sizes, so we know what your trying to supply steam to.0 -
well the raidiators vary in size .. most are 8 -10 fin ,
there's about 10 of them , then i have two risers that just go thru the bathrooms and kitchens with a vent at the top of each riser . hope that helps0 -
Sizing..........
the actual size of the house is a definate asset to have when calculating heat-loss, but with steam its different, are you putting new on the old rads?, then we have to know what the old rads are.0 -
im looking to replace the old boiler
the radiators are old cast0 -
Need to know
Type of radiators, number of tubes per section, center to center dimension of each section, height and width of each section....
There are reference books available on this site or you can do a web search for Radiator EDR or similar terms.
The information you provided is pretty thin when you see what really is needed.0 -
Yes
please go on...0 -
The Book is
"E.D.R."
Sorry Brad............
I didn`t mean to step-on-your-toes!0 -
Actually
I did not mean to horn in and step on yours! Good team we make!
Brad0 -
LOL..............
scuze me, as I kiss the sky, (or watch hockey, EH)!0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
