Bad T'Stat. . .
JP!
JP! Member Posts: 5
Will that heat from the fridge condenser penetrate a 4 inch thick wall, and affect the tstat?... Its digital.. so there's no mercury....
  • JP!
    JP! Member Posts: 5
    bad T'stat...
    Here's the deal...
    T'stat constantly reads 85, its digital... but when we take it outside or put it in the freezer it reads the current temp... brand new t'stat....
    customer says he has to raise the temp to 90, and then shut it off manually when he feels its hot enough because it wont shut off on its own...
    on the wall behind, where the t'stat is located, there's the fridge... so i'm wondering if thats a heat source affecting the thermostat...
  • Timco
    Timco Member Posts: 3,040
    Have you shot the wall the tstat sits on with a IR thermometer?
    T
  • Timco
    Depends on how much breathing room the fridge has, or how confined it is. Easiest thing is to measure the wall tep...
  • Uni R_2
    Uni R_2 Member Posts: 589
  • Plumdog_2
    Plumdog_2 Member Posts: 870
    It could
    I make little "shadow box" frames and put 1 inch rigid insulation inside, and mount the stat to the insul board. Works on outside walls when no other is available.
  • ed rockwelll
    ed rockwelll Member Posts: 3
    maybeeeeeeeeeeeeeeee a programable check settings
