pri/sec piping & bypass?
Timco
Timco Member Posts: 3,040
Is there a specific rule of thumb for applying pri / sec piping? If this method is used, is a boiler bypass needed?
Thanks again,
Tim
  • Brad White_136
    Brad White_136 Member Posts: 7
    Tim
    Could you be more specific as to type of boiler, (e.g.: cast iron, mod-con, copper tube, etc.) type of system (e.g.: converted gravity, fin-tube, radiant floors, etc.)
    Just want to be sure what the application is and why you are asking.
    As a general answer, primary-secondary in effect works as a bypass by maintaining the boiler temperature independently of the distribution temperature. How that is done differs of course.
  • Timco
    Thanks a lot for the reply....I am replacing a snow man with a cast iron atmospheric boiler, 162,000 BTUH. The old system has two 2" loops. Figured I would move these seperate wit 15-58's rather than as one zone with a 2600 series. Now it has a big 'ol B&G and the water moves too fast. Takes forever to heat up. Heatloss is just shy of 160,000. Would pri / sec be better than a fixed flow control on a bypass? No reset for now....I quoted and they opted for later.
    Thanks again,
    Tim
  • Timco
    Forgot to mention this system has many rads....CI. If dist temp does not need to be independant of the boiler temp, as with slab heat, then a typical bypass is the ticket?
    t
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    Tim, I prefer P-S
    and the secondary circ should be sized to the EDR rather than the heat loss. How much EDR is there?
  • Timco
    I have that number somewhere....Will need to find it. I got the total EDR for each rad, but am not sure what rads are on what loop. Two loops. If I am using 15-58's, shouldn't I be able to dial them in?
    Thanks again,
    T
    Probably
    but I bet you find you can run both loops with just one 15-58 or similar circ. There's only so much radiation you can serve with 2-inch pipe.
  • Timco
    I was figuring the cost of 2 15-58's was less than one 2664. House is fairly large...runs up 3 storis then out from there as best as I can tell. I tend to play safe & oversize...that's the beauty of the 3-speed selection.
    T
