what is it??
keith_20
Member Posts: 11
seen this on the basement wall of a customers home on friday! is this a type of outdoor reset?
I think so
where do those capillary tubes go? If it's reset, one will go to an outdoor sensor and the other to a pipe or radiator.
It looks like a tempeture reset but not need be out door reset. some small apt. buildings use these as remote thermostats usually wirid in with timers.
It's
a reset control. Here are the specs:Retired and loving it.0 -
Yup,,,,,,,,,,,,,,,,,,
that`s an old Minneapolis-Honeywell reset contol, and you guy`s thought this was new "stuff", generally you set this to a "stoker".0 -
thanks guys! it looked like some sort of a reset control. will take a closer look next trip there.0 -
capillary 'liquid' in old reset control
It's a treat to see the old spec sheets - I especially like the warning about locating sensors where they can't be molested by children....
But now I'm curious - just what IS the "hydraulic (all-liquid) fill" in the capsule and capillary? Might it be mercury?
Vbob0 -
Probably.. and correct on the \"Stoker\" comment above
You are probably correct in your guess of mercury as the capilary fill agent. It might be alcohol based - but given the age most likely mercury.
The comment above on how these were often used on coal stokers is also correct. Probably about 1/2 of the home coal furnaces and stokers I helped service as a kid had them connected in a circuit with a timer for the stoker (the stoker would run a minimum amount periodially to keep the fire going- by the timer, and then the outdoor reset control could call for more running time for the stoker based on outdoor temperature).
Perry0 -
yes this house is 1920-30 era. a old gas conversion burner is there now but i would say it was a coal stoker at the time. customer would like to upgrade next spring.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 918 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
