Steam Head Question for you
Joe V
Member Posts: 24
many years ago and it paid itself off during the first half of that heating season. And, no nuisance flame outs.
intermiten ignition system (Steamhead)
Do you think it's a 160 dollar investment to get honeywells intermitten piliot system? I have an Old peerless boiler and it's pilot stays on 24 7 during season.
http://www.honeywell-thermostat.com/honeywell/gas-valve-honeywell-y8610f5003.htm
Also i noticed some boiler cleaning fluid at home depot, wouuld that be good to clean the pipes and boiler? if so where would I empty it?
thanks for you help0 -
Thanks Joe
how was the installaion ? looks a bit complex.0 -
It wasn't bad
...but I'm heavy into electrical/mechanical/burners & control in experience.
It would still be worth it if you paid someone else to do it.
If I remember right (it was about 14 yrs ago), it came with its own gas valve that has to be piped in; flame rod to be installed near the burner rail with copper tubing to the valve; 110VAC; and the t'stat wired in.0 -
There are two opinions on these retrofit kits
One: The pilot should stay on 24/7 to keep the boiler's fire side dry.
Two: The use of electric ignition will prevent nuisance pilot outages and save some gas. They also react to a flame failure much more quickly than a standing pilot system will.
Personally I prefer electric ignition, since current systems are much more reliable than older ones were. The proper way to retrofit an older unit is with a kit like the Honeywell Y8610 where all the components are intended to be installed and used together, and are so certified. Also, THESE KITS MUST BE INSTALLED BY A PROFESSIONAL! This is definitely NOT a DIY job.
I don't like to use chemicals in steam boilers, since they must be flushed completely out of the system when you're finished cleaning. Also some chemicals will damage the seals used in some boilers (as Smith or Weil-McLain).
Thank You
Thank you Guys , I will look into getting that retro fit system them.
Thanks again .0 -
Joe, was that
the White-Rodgers kit?
No,
It was a honeywell Y8600.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 919 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
