oil tank location
Leo
Leo Member Posts: 770
If your oil tank is older you may awaken the sleeping dog and cause a leak. Another thing, MAKE SURE the fill pipe is removed from the outside UNTIL it is reattached to the tank. The delivery guy is used to filling a fill pipe attached to a tank.
Leo
  • Tim Gardner
    Tim Gardner Member Posts: 183
    I'm relocating my oil tank
    Is there a minimum distance between an indoor oil tank and the main house sewer trap?
  • Paul Fredricks_3
    Paul Fredricks_3 Member Posts: 1,556
    I don't kow if there is a code for that, but you'd better leave enough room to not only get to it, but to also work on it. I'd leave at least 2 feet.
  • Big Ed
    Big Ed Member Posts: 1,117
    Sure its Code
    Its the code of common sense :)
  • Weezbo
    Weezbo Member Posts: 6,231
    you could consider leaving the same work room clearances as a
    cleanout for that size of drainage pipe....
  • Tim Gardner
    if I had enough common sense
    I probably wouldn't be moving the tank again ...
  • Tim Gardner
    How much should that be for a 4" main trap?
  • Weezbo
    707.9
    in the 20002 UPC suggeststhe parameters. if you dont have a code book
    it goes something like 18" in front of the cleanout,verticle and 30 " horizontal, with consideration to the removal of the fitting...
    in other words leave enough space in order that you may work on it in the future. cleanouts generally need to be brought up out of a floor to grade....in your case it would be similar to a backwater valve...being able to take things apart and put them together is a good idea.
  • Tim Gardner
    Thanks.
  • Tim Gardner
    the sleeping dog was blocking the window
    so I moved it but then people complained about it being too close to the fire. So I'm moving it again. If it starts leaking I'll replace it but it looks very solid so far.
    I removed the fill spout -- thanks for the warning.
