Installing my new circulator
ralman
ralman Member Posts: 231
I am a little slow, and I am constantly second guessing things. It is chilly in here. Thanks for your concerns. I am going to post a picture.
  • ralman
    Installing new circulator
    I am installing a new circulator and the old circulator gaskets appear to have grease on the flange gaskets. The installation instructions do not mention anything, so I assume they are installed dry. Is that a correct assumption?
  • Weezbo
    Weezbo Member Posts: 6,232
    should you ever have to remove the pump or flange....
    a thin coating of teflon paste on one side of the gasket will generally make when you reconnect the flange or allow the gasket to be easily removed from one surface.
  • ralman
    Thanks Weezbo.
    I appreciate your assistance.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,563
    NeverSeize
    NeverSeize is often used on gaskets as well.
  • Hey Ross................
    did ya not get that boiler up-and-running yet? I figured you you were warm and toasty by now. Winter`s very close!!!
  • Empire_2
    Empire_2 Member Posts: 2,340
    Interesting....
    I have used spit, B&G oil on fingers to lightly coat gasket, But never leak lock , or never seize...... all we need is more crap in the system....;-)
    Mike T.
